how to create a perforated beam
How can I create a perforated beam on archicad 18 ? I did not find anything in the library, neither on BIMobject.com and I didn't succeed with the truss maker tool. i would like to avoid doing it with shape tool.
do you have any advices ?
thanks
9 REPLIES 9
If it is a simple circular or rectangular hole (or holes) you are after just select the beam, click on it and use the pet pallet option (top right) to add holes.
thanks for the answer, but I was thinking about a steel perforated beam, like that :
sinceV6
Hi.
Assign a complex profile to the beam, and make the holes like Stuart said.
Best regards.
great! thank you guys. Holes can be incremented, it's pretty quick!
luciant
You can also use the object Web Beam Curved 18. It can be made to be straight as well as curved and has many options for the holes.
IMac OS X 10.13.5
4 core Intel 3.4 Ghz, 16 GB Ram,
AMD Radeon HD 6970M
Archicad 15, 16, 17, 18, 19, 21, 23
rob2218
where do you straighten out (make it flat) this curved beam?
I looked thru all the parameters...no where does it allow you to make it straight (flat as in NOT curved upward).
i>u
Edgewater, FL!
SOFTWARE VERSION:
Archicad 22, Archicad 23
Windows7 -OS, MAC Maverick OS
rob,
you can do it from the 3D window!!
i am aware on how to create holes in beams but for my situration archicad wont allow me to even make a hole! The option is there but cant use it.
Please can anyone help?
You need to tell us more, which version of AC, maybe a screen shot, whats the situation you mentioned?
