how to create vectorial fills
I want to create my own vectorial fills.
The only way I know how to do this is by modifying existing vectorial fills, and this is very limited.
If I create bitmap fills everything is possible but these make the dwg-files I publish very large.
The GDL manual explains about making your own vectorial fills, but this works only with the object you write the code in.
Is there another way to make vectorial fills?
Hielke
12 REPLIES 12
I use a great number of "define fill" fills. The easiest way to start a new fill is to save the existing archicad fills "as gdl" from the Special menu and then make changes as needed.
If you put your own fills in a folder containing "Master_gdl" and then load the folder along with your libraries it will be in the list along with the native fills.
Please help to creat and use vectorial fills in 3D.
Thx
David Maudlin
To create a vectorial fill, in the Help files see:
Documentation > Drafting > Fills > Create or Edit Symbol Fill
To assign a vectorial fill to a material for 3D, in the Help files see:
User Interface Reference > Dialog Boxes > Material Settings Dialog Box > Material Vectorial Hatching Panel
David
David Maudlin / Architect
www.davidmaudlin.com
Digital Architecture
