‎2008-12-10
07:27 PM
‎2023-05-23
03:06 PM
Rubia Torres
‎2008-12-10 09:39 PM
babs_80 wrote:For the top of the wall, use SEO (Solid Element Operation) - can be found in the <Design> menu.
might be a stupid question, but i do not know how to draw this wall with the roof shape and the windows in order to get a 3d model?
‎2008-12-10 09:43 PM
‎2008-12-10 10:26 PM
Peter wrote:Hi Peter,
The dutch gable wall can be made by making the gable shape using TrussMaker
‎2008-12-10 11:44 PM
‎2008-12-11 12:10 AM
‎2008-12-11 06:25 AM
GeNOS wrote:The elements (lines, arcs) used to create the truss are joining perfectly. As a matter of fact, I've used the same file for creating the same truss in AC11 (here everything is ok).
some of your 2D line work might not have been jointed perfectly??
‎2008-12-11 06:33 AM
Peter wrote:Hello Peter,
I wonder if you make a shape using TrussMaker
in AC 11 then copy and paste it into an AC 12 project it comes in
intact or busted.
‎2008-12-11 06:40 AM
adytc wrote:ill give it a go with lines and archs. BRBGeNOS wrote:The elements (lines, arcs) used to create the truss are joining perfectly. As a matter of fact, I've used the same file for creating the same truss in AC11 (here everything is ok).
In AC12, I've tried to create a polyline using the magic wand (tracing the above mentioned elements); the truss created from this polyline is ok. So I guess the problem occurs only with elements such as arcs and lines. Can you (or someone else) please try the first method (the one with lines and arcs) and post the result?
Thank you in advance,
Adrian Tudoreanu
‎2008-12-11 06:47 AM
