2004-10-17 01:17 AM - last edited on 2023-05-23 05:25 PM by Rubia Torres
2004-10-17 01:53 AM
lsid wrote:If you had created the objects by programming in GDL, then I assume you would know the answer. So... I assume that you saved your objects from the plan or 3D window? The changes WILL require some very basic GDL, but it is pretty simple stuff.
I need to make changes to the object fI've created for example, fill,materials, pen, etc. How do i do that?
2004-10-17 01:58 AM
2004-10-17 03:06 AM
lsid wrote:Aha. Yes, this is something different - I thought you wanted to parameterize existing elements. I'll answer in the thread where you post your example:
thanks karl.
i'm slowly getting there. i just open the libary part of the object and seeing a list of stuff there that i can add into the library part. i am tyring to add the background fill because my object is 'transparent' on 2d plan....
