importing pdf's into plotmaker
Hello all,
Was just hoping somebody could help/answer a question about Plotmaker.
Q. Is it possible to import PDF's into Plotmaker, as they seem to go into plotmaker (Version 3.1.0 R2 INT (2284) okay, but they are just displayed as the adobe acrobat writer icon with adobe document written underneath.
The pdf's are written from photoshop CS 8 ( i have tried the save as...photoshop pdf, and as a straight forward print using the amyuni pdf writer as the specified printer).
oh, the background to the reason to use pdf's in this way is that I am adding coloured hedges and trees to the background of a line drawing elevation from archicad - saved from archicad as a pdf.
thanks in anticipation of response(s)
Oh and this is my first post to the forum so apologises if this is all wrong/missing information.
cheers,
Dave G. (designworx)
8 REPLIES 8
TomWaltz
Dave
alas, this is a long-standing complain.
At this time, Plotmaker cannot import PDFs.
Your post is fine, though it's a good idea to put you Archicad version, Operating System, and hardware in your signature (in your user profile), to help answer version-specific questions.
Tom Waltz
Thanks for the reply,
Bizarrely It makes me feel better, as in, its not my ineptitude at archicad/plotmaker.
Any ideas as too how I can acheive the end result desired, ie areas of jpeg, bmp, tiff etc onto a line (vector) drawing, into plotmaker? Any advice or ideas on this would be much appreciated.
Am using Archicad 8.1 r2 on a pentium 3, 1.7 mhz, 128? mb, I have photoshop CS, indesign 2.0, illustrator 10, art-lantis 4.5...to play with.
cheers,
Dave G (designworx)
TomWaltz
I'm not sure I understand what you mean "areas of" jpgs, tiffs, etc.
You can place bitmaps into Archicad or into Plotmaker. Just not PDF's.
Tom Waltz
I had been clone stamp 'painting' from the swatch of foliage from the textures library over the hedges/foliage on the pdf of the elevation in photoshop, then saving as a pdf to open in Plotmaker (or so i hoped)
thanks for the repolies.
Dave G.
designworx wrote:
I had been ... in photoshop, then saving as a pdf to open in Plotmaker (or so i hoped)
Maybe I'm missing something, but ... can you not save as 'almost anything else' from PS? There are a lot of image formats than Plotmaker can handle, just not pdf's.
- Stuart
- Stuart
PlotMaker can read Photoshop files directly. No need to "Save As..." anything.
Djordje
Keep it as PSD (Photoshop native). It will go straight into PlotMaker, and will be live if you need more changes, so that the update is automatic too.
Djordje
ArchiCAD since 4.55 ... 1995
HP Omen
OK, thanks thats great, and thanks for everyones responses.
