interior elevation markers
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
‎2009-04-07 08:04 PM
‎2009-04-07
08:04 PM
1. When I delete one or more of the interior elevations It unlinks the reference to the drawing. I have double checked the links and everything is ok. When I restore all the interior elevations it works again. I am using the IE marker 1 when doing this. The only fix that i have for this is to change the text to custom but that defeats the pupose of linking drawings if I still have to spend all my time checking keys. Check out kitchen space marker.
2. I want to be able to add additional keys that are
any thoughts
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2009-04-08 07:32 AM
‎2009-04-08
07:32 AM
tjbota wrote:Does it happen when just the North Elevation is deleted? It's a bug.... read HERE, 7 or 8 posts down. James had a workaround.
tjbota wrote:I don't think you can link more than one IE marker to a drawing/viewpoint.
2. I want to be able to add additional keys that arelinkedto specific drawings. trying to keep my graphics the same throughout my drawings.
One suggestion, if you do use a IE marker with "Custom" text... assign a RED pen for the marker (in model view - black for layout) so you can identify (by color) which markers need to be updated manually.
EDIT: For Bad grammar... typing too fast.
Marc Corney, Architect
Red Canoe Architecture, P. A.
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2009-04-08 02:39 PM
‎2009-04-08
02:39 PM
Thanks,
Two great ideas,
You were right about the bug. For the deleting of elevations, I ended up just placing them off to the side, on the correct layout, and made its ID a period "." that way a simple dot only shows up where the number is suppose to be. I also changed the elevations to manually update so it is not slowing down my computer.
I ended up using custom text and changing the colors for the additional keys. It seems a little silly that you can link section markers all you want but not interior elevations. I am going to try and figure that one out in my spare time, so no time soon.
Two great ideas,
