internal doors,stairs,etc... on elevations
I want to see all elevation but i don't want to see what's happening behind the windows.
If i use limited section mark i can't see all lines on the roof or other elevation's outlines.
What's the solution?[/img]
3 Replies 3
What version are you on? It would help if you include it in your signature so that the help can be tailored to your version.
In 10, go to View - 3D View Mode - 3D Window Settings and make sure that Transparancy in Shading is set to OFF.
In 9, go to the screen that deals with the 3D window settings and do the same. I don't have 9 running right now and I forget exactly what the menus are called to give you a step-by-step.
Thank you Sergio,
It's ok now
I'll post an other question
Keep in mind that your transparency settings are "secretly" stored with your views so you will have to redefine views that have already been set up. There are a few of these that graphisoft hides from us by not including them in the view setting.
