is it possible to convert an logo image into an object
muzedesigns
Hello!
Apologies for the ambiguous subject heading..
Basically what i am attempting to do is take a logo and then 'trace it' (slab + space bar) in archicad as a slab - then save as an object in the right orientation to then use as signage on a building.
I am positive i have done it in the past but apparently my brain has copped out on me today - or else i have just officially lost it!
Any ideas if this is possible and how to go about achieving it?
Thanks for your time!
Chrissy
Chrissy Avramidis
|| ArchiCAD Versions 7-22 ||
|| 27inch iMac Pro (2017) | macOS High Sierra 10.13.6 | Processor 3 GHz Xeon W | Memory 64GB 2666 MHz DDR4 | Graphics Radeon Pro Vega 64 16368 MB||
12 REPLIES 12
Hi Chrissy
If your logo comprises of just text, you can use "TEXT 3D" object in the standard ArchiCAD library.
However, if it is the actual graphic logo that you are trying to create, what you have described is the easiest way of creating it, I suppose (i.e. slab tool to magic-wand the outlines of the design, rotating it in 3D-axo view and saving it as a .gsm object).
muzedesigns
Thanks Shingo!
Unfortunately it is not just text - i wish it were!
It is quite a detailed emblem for a school crest.
the slab tool to magic wand is the plan;
I just can't remember how to make the photoshop image regions (or logo edges) 'findable'.
Any ideas?
Chrissy Avramidis
Link
You'd need to get some Raster-to-Vector software to convert the image into 'findable' elements. And even then, it probably won't be such a great conversion.
I'd recommend scaling the image up to many times it's intended size, then tracing around it with 2D elements, like lines, arcs, splines, etc. Remember to copy and mirror wherever possible to save you time and ensure symmetry. Then scale it back down to it's original size and magic wand a slab onto it.
You could also do all of this in the Complex Profile window and just make a wall or beam out of it. That would save you having to make an object. Just a thought.
Link.
Dwight
Illustrator is one such raster-to-vector software that works nice with Archicad.
Dwight Atkinson
muzedesigns
thanks Link - i will try playing with it in illustrator - it is unfortunately very detailed
Chrissy
Chrissy Avramidis
muzedesigns
Sorry Dwight! - i didn't see your message! Thank you as well!!
Chrissy Avramidis
mmm..excuse me...but i am now really very curious to have a look on this logo !!!!
i mean if its possible?
sorry ... but u know its curiosity..u can't control it !
muzedesigns
No worries Whatever - here you go!
Chrissy Avramidis
Link
Yes, apart from the lettering and the flames you could mirror everything else, nearly halving your work.
However, Illustrator may produce good results. Will be interesting to hear how it works out for you.
Link.
