key shortcuts
I have encountered a strange problem with key shortcuts using AC9.
For example, I assigned Cmd-D for Drag , Option-D for Drag a copy, and Option-W for Mirror a copy and so forth. Out of the blue , the key shortcuts would temporarily stop working. It would resume its function if I go back to the Option Menu and re-assign them. Then the same problem would mysteriously happen again. The intervals between problems runs about 1 hour. Does anyone else come across this problem and have a way to solve it?
__archiben
there's more on this here:
http://archicad-talk.graphisoft.com/viewtopic.php?p=23557#23557
make sure tech-support are aware . . .
~/archiben
b e n _ f r o s t
