Toni Mayerhofer
Quick 90 degrees rotate command.
Hi Community.
I got sick of waiting for Graphisoft to implement a function to rotate geometry quickly by 90 degrees, like whacking the spacebar in Revit.
So I built my own dirty version using AutoHotKey.
1. Install AHK v2 (with your admin's blessing) it's harmless.
2. Paste the below code into a new text file saved as *.ahk, on your machine.
^Space::
BlockInput("On") ; Temporarily block all user input
Send("{Ctrl up}") ; Release Ctrl key if held
Sleep(20)
BlockInput("Off") ; Allow input again
Sleep(10)
Send("^d") ; Send clean Ctrl+d
Sleep(10)
Click()
Sleep(10)
Send("1")
Send("{Enter}")
Sleep(10)
Send("90")
Send("{Enter}")
3. Put a shortcut to this script in your startup folder, so it's always on when you start windows.
Now I can use ctrl+Spacebar to rotate whatever I have selected in plans or 3d windows. Nice little timesaver. feel free to adapt to your own workflow.
Mike
Notes:
Assumes Ctrl+Space is unassigned in your Archicad shortcuts, either clear it in AC or reassign in the code to something you prefer.
"^d" refers to "Ctrl+d" which is my rotate shortcut, replace in the code with your own shortcut or reassign to Ctrl+d in Archicad
Assumes using degrees,
Works by simply recreating the key sequence of shortcut to rotate, clicking 3-points and defining 90 degrees. won't copy and rotate.
No guarentees and not responsible for any malfunctioning on your machine.
I have a couple other timesavers with AHK if anyone is interested.
Operating system used: Windows 6020 AUT
9 Replies 9
CosminF
This quick rotation is already available in archicad, starting from version 29.
https://help.graphisoft.com/AC/29/INT/_AC29_Help/005_NewFeatures/005_NewFeatures-6.htm
Cosmin Furdui - architect @ Wincon
AC 27, running on Windows 11 Intel(R) Core(TM) i7-14700K CPU64, 3.40GHz, 32GB RAM, Nvidia GeForce RTX5060 32GB
Lingwisyer
Guru
Other than all the AI (that require you to be on a subscription plan) and MEP things, quick rotate was one of the headline features of AC29 which came out two months ago.
jl_lt
Ace
quick rotate = the highlight of the year
vistasp
Mentor
It would be interesting to see the other AHKs you have made for Archicad.
= v i s t a s p =
bT Square Peg
https://www.btsquarepeg.com
Toni Mayerhofer
This is so funny! Only took AC 15 years.
Toni Mayerhofer
Let me just flip through the other new features of AC 29 to check they arent redundant also!
Turit
There is also a free add-on for older versions (26-27-28).
cuba
Maybe make one similar to mirror objects?
Apple M1 Max 32 GB
Latest AC
FWRD_151
Does anyone know why quick rotate does not work in the profile manager?
