2 weeks ago - last edited 2 weeks ago
Hi Community.
I got sick of waiting for Graphisoft to implement a function to rotate geometry quickly by 90 degrees, like whacking the spacebar in Revit.
So I built my own dirty version using AutoHotKey.
1. Install AHK v2 (with your admin's blessing) it's harmless.
2. Paste the below code into a new text file saved as *.ahk, on your machine.
^Space::
BlockInput("On") ; Temporarily block all user input
Send("{Ctrl up}") ; Release Ctrl key if held
Sleep(20)
BlockInput("Off") ; Allow input again
Sleep(10)
Send("^d") ; Send clean Ctrl+d
Sleep(10)
Click()
Sleep(10)
Send("1")
Send("{Enter}")
Sleep(10)
Send("90")
Send("{Enter}")
3. Put a shortcut to this script in your startup folder, so it's always on when you start windows.
Now I can use ctrl+Spacebar to rotate whatever I have selected in plans or 3d windows. Nice little timesaver. feel free to adapt to your own workflow.
Mike
Notes:
Assumes Ctrl+Space is unassigned in your Archicad shortcuts, either clear it in AC or reassign in the code to something you prefer.
"^d" refers to "Ctrl+d" which is my rotate shortcut, replace in the code with your own shortcut or reassign to Ctrl+d in Archicad
Assumes using degrees,
Works by simply recreating the key sequence of shortcut to rotate, clicking 3-points and defining 90 degrees. won't copy and rotate.
No guarentees and not responsible for any malfunctioning on your machine.
I have a couple other timesavers with AHK if anyone is interested.
Operating system used: Windows 6020 AUT
2 weeks ago
This quick rotation is already available in archicad, starting from version 29.
https://help.graphisoft.com/AC/29/INT/_AC29_Help/005_NewFeatures/005_NewFeatures-6.htm
a week ago
Other than all the AI (that require you to be on a subscription plan) and MEP things, quick rotate was one of the headline features of AC29 which came out two months ago.
a week ago
quick rotate = the highlight of the year
a week ago
It would be interesting to see the other AHKs you have made for Archicad.
a week ago
This is so funny! Only took AC 15 years.
a week ago
Let me just flip through the other new features of AC 29 to check they arent redundant also!
a week ago
There is also a free add-on for older versions (26-27-28).
a week ago
Maybe make one similar to mirror objects?
