keyboard shortcut scheme
Hi all, just moved over to a new MacBookPro and AC24 (from 23) and am having trouble bringing over my keyboard shortcut scheme from the old mac. (probably pilot error & some brain fade). Can someone please explain the preferred method to do this? Thanks! Leif
1 Reply 1
On the old MAC you open the Work Environment settings.
You can select the main WE parent folder or you can select just the shortcut folder.
Then there will be an "Export" button to save the file to a location of your choice.
Then in the new machine you import that file in.
Then make sure you are using that new WE (i.e. set it as default) or if you just imported the shortcut scheme, set that to be used in your current (active) WE.
