label tool
Is there a way to get the Label Tool to set the labels to the left of the leader? If so, how?
Thanks,
John
Aussie John
John, When you setup the auto label for the wall, go to the Text Label panel and change the to 180º
Alternatively change one of the labels to the opposite side then Opt/click to change the default. Next time you apply the label it will match the manually changed one.
Once placed just select and change in the forementioned Text Label panel
Unfortunately you dont seem to be able to change the lengths of the lines except manually.
Cheers John
[/size]
John,
Thanks for your quick reply. I had some bug going on with the label tool that lead to several problems. It seems that the problems were cured by changing the layer of the tool and the restarting ArchiCAD--go figure.
Thanks,
John
