library loading wierdness
My boss has been working on a project for a couple of days now, in AC9, which was created in AC6.5. When he opens the file the library manager screen shows the 6.5 library as being loaded, but he has to manually add the AC9 library everytime he opens the file, and the last 2 times he's opened it the library manager never came up, and it didn't load the AC9 library. I have no idea why the project / ArchiCAD is acting this wa... anyone have any ideas?
cheers,
dan
4 Replies 4
Erika Epstein
Did your boss do a save after adding the AC90 library?
Erika
Architect, Consultant
Mac OSX 10.11.1
AC5-18
Onuma System
I asked him and he said yes (so probably not) but I opened the project on his machine then saved it, and the same problem persists.
Erika Epstein
Daniel,
Check that your boss's libraries are loading correctly. When you open the library manager, the libraries, if you want them to be remembered, should be from the computer/network, not the virtual library that is loaded. they should be from the tab that says Local/Lan.
HTH
Erika
Mac OSX 10.11.1
AC5-18
Onuma System
Ill double check to make sure they're coming from the local/lan tab, hopefully that fixes the problem.
cheers,
dan
