limited section cut limit setting?
does anyone know how to set the limit of the limited section cut? I'd like to narrow it, but there doesn't seem to be the opportunity to do so.
Thanks--
John
Thanks--
John
John,
I assume you have toggled show/hide section depth lines under Options Display so that you can see the limits. Then it's just a simple matter of using the stretch command to adjust the depth.
Wally
uh, duh.
that is exactly it.
thank you!
John
