lines are thin/grey where the walls connect?
Can anyone help me figure out why the lines are thin/grey where the walls connect(see picture)? I recently upgraded to Archicad 24 so I'm figuring out the differences. I have clean wall intersections checked so I'm stumped. Any help would be appreciated. Thanks.
1 Solution
Have a look at the end line option in your composite settings.
I tend to set the end line pen the same as the skin lines, and if you can't or don't want to use the same pen (colour), choose another that at least has the same width.
Go to post
2 Replies 2
Yes that was it!! Thanks so much!!
