cremsberg
lines at ends of window & door openings?
Using version 10 windows & doors and "Show Opening Only" in Model View Options, how do I get solid lines at both ends of the opening?
Claire Remsberg
Remsberg Architecture, P.A.
MacBook Pro, OSX 12.6, ArchiCAD v25 (5010)
David Maudlin
Claire:
In the Model View Options, you will need to check the "with Contours" option, which will add the opening ends, as well as the head. I believe this is only controlled by the Model View Options, the library does not matter.
David
David Maudlin / Architect
www.davidmaudlin.com
Digital Architecture
