We value your input!
lines dissappear on section rebuild
Some of my colleagues had a very odd problem... while they tried to rebuild section from model some lines they had drawn before simply were removed from the section.
And today I've seen it with my own eyes. You can try it yourself, just open Orchard Project from the Archicad Examples folder and try to rebuild section B from model
any suggestions?
6 REPLIES 6
On which version of AC?
AC 9 (1812 int)
Are you sure these are lines that they drew and not ones that they modified from the automatic section drawing?
ArchiCAD will erase all lines that it originally drew, even if they have been modified.
heh... I think you're right, Matthew. Your suggestion seems to explain everything. Someone just need to draw more accurate
TomWaltz
One more reason to not use the "Drawing" mode for sections...
Tom Waltz
Djordje
any suggestions?
Don't unlink.
Djordje
ArchiCAD since 4.55 ... 1995
HP Omen
