2022-01-01 09:36 PM
Im trying to find a way to lock to z axis in 3d view.
how??
Thanks 🙂
2022-01-02 01:40 AM - edited 2022-01-02 02:03 AM
You can pick your editing plane to be vertical before you create or modify any element, pls check these 3 screenshots from Archicad 25 reference guide they may help.
2022-01-02 07:12 AM
I prefer using lock to guide command and activate it once you are in the z plan of your movement.
2022-01-02 04:22 PM
Thanks. I have just realised that when the 3D grid is on there is an z axis guide. I dont usually have the 3d grid on. You are right, its the way to go.
2022-01-02 04:23 PM
Thanks, Im going to start to do this.
2023-03-06 10:47 AM
What is the lock to guide command? Is there a shortcut for it?
2023-03-06 02:19 PM
Have you tried the SHIFT key?
Barry
2023-03-07 05:21 AM
Holding shif works but you can find the shortcut In The work environment. It's nice because you don't have to hold shift when using lock to guide
2023-03-07 11:29 AM
I had a search in the work environment shortcuts but could find anything for lock to guidelines. Im on 25 though, perhaps its only in 26?
2023-03-08 02:44 AM
I just checked 22 and it has been there since at least then.
I still like just using SHIFT because as soon as you let go, it unlocks.
Using the shortcut, if you want to unlock, you have to press the shortcut again.
