making an arch
I have a small problem. I am trying to create a simple arch with columns to support it and do not know how to rotate the object from the floor plan to view it in elevation?/? Please help!
3 Replies 3
Check the thread "rotate in verticals" in this forum (it is a fairly current topic). The process was for creating a different shape but the steps should remain the same.
Aussie John
You could use the flat arch door to create an arch opening. Then use a wall to subtract the lower opening using Solid element operations. Then add columns.
Cheers John
[/size]
One other option is the barrel vault roof. This could be used to easily create the arch in 3d and in the vertical direction.
