mesh in setion
Hello
Does anyone know how to create a section which can hide the mesh line where behind the cutting section line? I mean i do not want to see the mesh line behind the section line, but i want to see the building behind the section line?
EY
10 REPLIES 10
Link
There is no automatic way of doing that, but please feel free to add it to the wishlist section. You're not the only one who wants to hide the distant contour lines!
Seems the best workaround at the moment is to trace your ground line and hide the mesh. Sorry for the bad news.
Link.
You don't want to see the mesh contours, but you do want to see the line where the building meets the ground? Is that right?
Make the mesh with a non-printing pen. Cut the hole for the building using solid element operations. Subtract up with slabs drawn with the pen you want for the ground line, and use Inherit Attributes of Operator.
James Murray
Archicad 27 • Rill Architects • macOS • OnLand.info
Link
Gidday James
Haven't tried this to see how it works (because I am strapped for time), but won't this create a whole new set of problems? We want the mesh to print in plan right? Won't it also take on the material of the slab?
Cheers mate,
Link.
Not me. My site mesh is 3D only, the site plan topo is 2D. I can't stand the zigzaggy contours or the fact that the outline and contour pens are the same. If you do want the mesh in plan than printing it white wouldn't be good, true.
So one way the other you have to draw something. Funny how often it comes down to that.
James Murray
Hi James
You are right but what is the meaning of "Subtract up with slabs drawn with the pen you want for the ground line, and use Inherit Attributes of Operator." Could you give me some clues.
EY
Hi
What i really want is showing the cutting line in the section but not the line behind the cutting line. (eg. cut the hill has different level)
EY
EY wrote:
Hi James
EY
Solid Element Operations. In the reference guide starting on page 390. Access the Solid Element Operations palette from the tools menu. Among other things, briefly, SEOs let you cut one volume (target) with another (operator), and you can optionally cut up or down through the target. IMO this is the best way to cut meshes for buildings, because an SEO hole can have a bottom rather than going all the way through.
Another advantage: SEOs are 'live'. If you modify the shape of the operator, the shape of the hole will change. If you delete the slab, the hole goes away.
When you do an SEO, you choose what attributes you want the newly-created surfaces and edges to have. They can have the same attributes as the rest of the target element, or they can 'Inherit Attributes of Operator', taking on the pen and material of the element they were cut with. In your case, you can draw the mesh with a white-printing pen, and a cutting slab with a visible pen. In the layout the mesh surface and outline will be invisible, though not hidden, but you can see the lines of the hole.
Without giving the whole thing away, since it's beneficial to struggle: Place a slab with the shape of the building footprint, at the level of the bottom of the building. The bottom plane of this slab should align with the bottom of the building slab. Put this slab on a hidden layer. Do the SEO, mesh is target, slab is operator, operation is 'Subtraction with Upwards Extrusion', choose 'Inherit Attributes of Operator'. If the foundation has different levels, you'll need more slabs.
HTH,
James Murray
EY wrote:
Hi
EY
So you want to see the line where the section cuts the ground, but no other lines? If so, set the plan pens to something non-printing (white), and leave the section cut pen visible.
If not, how about a screenshot?
James Murray
Link
Access the Solid Element Operations palette from the tools menu...
James, James, James, James, James!
Sorry couldn't help myself! It's only because I know how good you are. Maybe this is the one you missed in the test?
Link.
