move more than hole inside slab
hello,
is there any way to move or select more than one hole in slab ?
I mean I can select one but ineed to move more than one? should I have to move it individually or there is a way to select more than one .
thank you
1 REPLY 1
Lingwisyer
Guru
You can use the marquee then ctrl + h to stretch the nodes. Isolate your slab first otherwise you may move other things at the same time.
Ling.
