my Archicad quits constanly
Juricsek Milla
when I open my Archicad it closes automatically after a few seconds, even when I am trying to move objects
can anybody help me with that? (I am using Archicad 24)
1 REPLY 1
So you are using Archicad 24 but you tagged your post Archicad 25?
You are using Window but what version?
Is your Archicad up to date with the latest update/hotfix (build 7000)?
What are your machine specifications?
Was it working fine before but has only just started happening now?
Even if you open an brand new file from the default template, does it still crash?
Have you searched these forums for a possible answer?
Do you have a support agreement with Graphisoft?
I am guessing maybe not if you are still using 24.
If you do, have you contacted your local Archicad Support?
Setup info provided by author
