no 2d symbols in archicad 15 when i deleted archicad 13!!!
Hello every one i was using project before on previous version of archicad and now i tried to use it on archicad 15 but it display small points without really 2d symbols i do not know if this happened because i deleted archicad 13 from my computer but what is the solution for this problem please help
and Thanks in advance
2 Replies 2
By deleting / uninstalling AC 13 you have removed AC 13 library, which is needed to load object that were made in that version of ArchiCAD.
You have to reinstall AC 13 or get AC 13 library. After that you have to load it in AC15 to get those objects.
Eduardo Rolon
mzex though that is an option it is not the most efficient.
You can run the consolidate library command from the Library Manager and it should update the objects by loading the appropriate libraries. In this case the AC15 library and the Migration Library for AC13.
Eduardo Rolón AIA NCARB
AC29 US/INT -> AC08
