user-jose
no automatic transitions between different pipe sizes
When I connect different pipe sizes in MEP no automatic transition is created as it is supposed to do. Any ideas why is this happening?
Setup info provided by author
3 Replies 3
Ricardo Lopez
Hi
Check if the pipe transition dimensions for your pipe sizes are available in the Table of Dimensions in the Route Specifications. If they don't exist they will not appear in your model.
Ricardo López, M. Arch.
Does this help at all?
https://community.graphisoft.com/t5/MEP/Intelligent-connections-and-editing/ta-p/694729
I am unsure as I don't use the MEP system.
There are 5 or 6 new knowledge based articles that have just been posted about the MEP system.
Or maybe one of the other articles will help.
user-jose
thank you
