2007-02-21 10:25 PM - last edited on 2023-05-25 06:15 PM by Rubia Torres
2007-02-21 10:41 PM
2007-02-22 01:48 AM
2007-02-22 03:33 AM
HANIEL wrote:Bruce, Peter and Mike are correct.
If I save a fiel as a template format/....... which I cannot find.
2007-02-22 05:40 AM
2007-12-16 03:17 PM
~/archiben wrote:
... be warned: regardless of which method, archicad willalwaysshow as the default template the file called "Archicad 10 Template.tpl" and saved in ./Applications/Graphisoft/ArchiCAD 10/Defaults/ArchiCAD/...
2007-12-17 01:30 AM
2007-12-17 11:02 AM
Link wrote:Thanks Link!
Next time when we Create a New Project using a template, AC will offer us a list of templates that will be divided in up to two sections, (depending on what you've done prior and your chosen Template Folder). Se the image. The first section lists the templates stored in your chosen Template Folder, and the second section lists the most recent templates you've accessed.
2008-01-23 12:56 AM
Thomas wrote:Yes, of course a recently used template will only appear in the appropriate place if you have recently used a template.
It seems this works a little bit differently on the Mac. I get the sections you mention only when IstartArchicad andmy chosen Template folder does not contain the recently used templates or the ones that are in the Default folder.
