perforated steel plate
how can create a perforated stell plate( with round perforations for example)? or even better, where I can find a object like this ?
Jens
12 REPLIES 12
Dwight
Such an object would require too many polygons to be practical since each tiny hole would be defined by at least eight polygons...... you'll use a fill pattern to define the surface in anything but a photo rendering, and in a photo rendering you'll use a texture map with a mask for transparent holes.
Attached is an example of a screen pattern I use.
Dwight Atkinson
Dwight
Depending on exactly what yu need, you can draw the pattern in photoshop or use a photo from a metal catalog.
This example is from a metal catalog for expanded metal.
Dwight Atkinson
Dwight
The success of the expanded metal material.
Dwight Atkinson
Dwight
try this one - can't attach masked jpg
Dwight Atkinson
Dwight
so it is an exercise in my book - use the pefed metal file to create this material - watch the sizing - note that for ArchiCAD 9, it uses the mask channel that ArchiCAD 8 does if you tell it to match.
Dwight Atkinson
Dwight
an example in use - LightWorks rendering - note flaw in LightWorks - can only render the front faces of the block - that perfed metal is wrapped all around the slab, but the rendering engine treats it like a folded sheet - look thru the holes to see what I mean.
BTW: see how the metal color is controlled through reflectivity rather than color - the texturemap is white. This way, other colrs can affect the surface more easily making the image more lively.
Dwight Atkinson
Dwight
Hey. Who's there?
Dwight Atkinson
__archiben
Dwight wrote:
Hey. Who's there?
there . . . there . . . ere . . . ere . . . re . . . e . . . e
[congratulations on entering the next phase mr atkinson! off to join matthew in the limo?]
cheers
~/archiben
b e n f r o s t
Dwight
Still feel pretty dumb. Pass me my cane, would you please?
In view of the fact that if this darned book is to ever get done, I must enter a manic phase, you all will be hearing from me a lot in the next weeks..... blah blah.
Dwight Atkinson
