2005-04-25 10:48 AM
2005-04-27 12:45 AM
2005-04-29 04:55 PM
2005-05-02 08:44 AM
Djorde says, try opening "the same AutoCAD drawing on a different machine and find your placed images", but has he tried moving a layout book to a different location on the Network and then finding the placed images?
Also: am I right in thinking that publisher (in Archicad) will only publish different storeys at the same scale? I've tried setting the scale within the publisher window - but it always seem to revert to the scale of the first storey in the set.
2005-05-09 01:14 PM
2005-05-10 02:08 PM
2005-05-10 02:41 PM
2005-05-10 10:20 PM
why are we dimensioning in AC and not PlotmakerWhy would you WANT to dimension in Plotmaker/Paper space? Shouldn't you be concerned about being able to see the text/dimensions/etc while you are working on your plans/elevations/etc?
2005-05-10 10:23 PM
2005-05-11 03:15 AM
but then use autocad to do image presentations such as this.... i'm still learning PM but for now i need productivity which PM does not havemate, can you send me a little bit of that stuff that you are raving on? It seems to be hell of a good one.
2005-05-11 04:34 AM
dbroughton wrote:which version of archiCAD/plotmaker are you using?
however i have to render each view which takes time... if i was to do a house plan etc. or another type of drawing i would use plotmaker for elevations, sections and plans... but then use autocad to do image presentations such as this.... i'm still learning PM but for now i need productivity which PM does not have...
