polyline question
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
ā2009-10-21 10:43 AM
ā2009-10-21
10:43 AM
i have some polylines imported from archicad, and they are made of hundreds of small line segments that define a curve for example...is there any way to approximate a curved line out of these?
ArchiCAD 11 build 1210
ArchiCAD 12 Hotfix 3
AMD Athlon 64X2 3800+, 2 GB DDR, Nvidia geforce 6600GT, Win XP SP2
6 REPLIES 6
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
ā2009-10-21 11:13 AM
ā2009-10-21
11:13 AM
Trace over it with a spline choosing every 10th or 20th node or whatever is necessary to get the curve to match.
You can edit (add or subtract) nodes to alter the spline if needed once you have placed it.
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
ā2009-10-21 11:19 AM
ā2009-10-21
11:19 AM
yeah...i started to do this with a polyline over the old one, to approximate the curves but it will take forever
magic wand doesn't help because it doesn't know how to "approximate"....so...i think the "manual" method is the only one...
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
ā2009-10-21 09:21 PM
ā2009-10-21
09:21 PM
One way to do it (still manual) is to explode the polyline into line segments, which will be grouped if auto grouping is on. Select the grouped lines and assign arrowheads to both ends (use circle "arrowhead") so you can see where the end of each segment is. You can then trace over picking as many or as few end points as you like.
HTH
HTH
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
ā2009-10-22 04:52 AM
ā2009-10-22
04:52 AM
I would create a spline first with three points - start of polyline, middle of polyline and end of polyline.
Then I would stat to add nodes to the spline (pet palette) so that it begins to match the curve of the polyline.
This way you just add as many nodes as you need.
More in the tight curvey sections and less along the straighter sections.
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
ā2009-10-22 05:34 AM
ā2009-10-22
05:34 AM
Magic wand a polyline using the linear segments with segment length method.
Selecting the appropriate segment length controls the accuracy of the magic wand overtrace.
EDIT: OOPS: missed a step:
Magic wand a spline to the polyline, delete the original polyline THEN magic wand a new polyline with tolerances as above.
Dwight Atkinson
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
ā2009-10-22 08:43 AM
ā2009-10-22
08:43 AM
Dwight wrote:Amin to that
thank you
