polyline to line
seda harmantepe
How can I convert polyline to line ?
Lee Hankins
Cmd+= on a Mac or possible ctrl+= on a PC will explode the poly line in to grouped lines and arcs. You can choose whether to keep the poly line too. You can also then convert the separate lines back to a poly line by using the consolidate line command.
Lee Hankins
ArchiCAD 4.5 - Archicad 29
macOS Tahoe (26.0)
Csongor BIRTOK
Hi, You can explode the polyline (CTRL + =), that way you gonna end up with multiple grouped lines.
Csongor BIRTƓK
CONSOFT Romania
Lee Hankins
Lee Hankins
macOS Tahoe (26.0)
Just use the 'explode' tool.
You can also use the 'Consolidate Line' tool to explode polylines.
