polylines
howdy
just migrating from v11 to v16
in v11.. when you exploded a polyline.. it created a series of grouped lines
in v16.. exploding a polyline results in a series of grouped polylines
the manual for v16 states that exploding a polyline will result in lines
i would like it to result in lines.. is there something i am missing
(note.. when i use the line consolidation command it dos explode it to lines... but that requires a whole handfull of additional mouse-presses that should not be necessary)
any help / insight greatly appreciated
thanks
yukioMishima
2 REPLIES 2
This is a change in the behavior of the explode command. There have been other complaints. I don't see any advantages to the new behavior so I too see it as a net loss but it's not something I do a lot so I just make do.
matthew
thanks for the reply
shame they changed the way it works.. we use it a lot.. esp importing DWG files and using them as base building drawings
thanks again
yukioMishima
