prefer roof pitch instead of angle
Jefferson
Wondering if there's a way to change the default display of roof angle in display box to roof pitch.........can't seem to locate a way
jeff white
w3d design
AC 23 Solo US / current build & library
Windoze 10 Pro 64
HP ZBook 17 G4
Intel Zeon 3.0
Twin 2GB SSD
32 GB memory
http://w3d-design.com
24 REPLIES 24
Graham wrote:
I am using AUS FULL version of v15 r3267 BUT I still only have the options of degrees or percentage slope in the Info Box or the Roof Settings.
How or why can this be?
Is the Slope (gradient) setting made available only in the US version of AC15?
Other non-US version users - can you comment? AUS, GER, SPA, POR, FIN etc?
I know that US users were quite adamant about needing this - but it seems odd that GS wouldn't just include it in all versions. Let's see what others report...
"Graham wrote:
I am using AUS FULL version of v15 r3267 BUT I still only have the options of degrees or percentage slope in the Info Box or the Roof Settings......"
Same here.
I can confirm the AUS version only has degrees and percent.
No rise/run or even degrees, minutes, seconds (even if working units are set to DMS).
INT version does not have this option either.
Stress Co_
Is it possible to change how Roof Pitch is displayed in the info box?
Marc Corney, Architect
Red Canoe Architecture, P. A.
