problem with story levels below zero
i have a wierd problem. I am picking up a project where someone else left off.
I want to create a foundation level that is 6' tall and -6' below level 0 - the main level.
when i go to story settings i see that the prior draftsman created a foundation level but their is no height for that level. Basically the foundation level is at 0'-0" same as the main level. When i try to enter -6' as my height to next level it beeps at me and goes back to 0. I cant figure out why i can not give the foundation level a height. There are objects drawn on this level I can see them in the 3d window but when I open the plan view of the foundation nothing is there. Anyone have any ideas?
THanks
The height to next story is always positive. It's equivalent to floor to floor height and so is absolute not relative which is why it won't accept a negative value. Enter a positive 6' and it will work. You can also enter the -6' as the story elevation on the left.
