License outage
Dear Customers, We are facing with an outage in our services in Azure. You may experience issues with the Azure-based functions, like licensing, BIMcloud SaaS, Learn Portal. We are working hard on this issue to make it fixed as soon as possible. Thank you for your patience.
projection of cursor
In plan when editing fills slabs roofs I use to be able to align a node 3 ways when moving it. Those 3 options appear in my control box but I am not allowed to use them. I recently moved from ArchiCAD 14 to 16. Am I missing something?
file:///C:/Program%20Files/Graphisoft/ArchiCAD%2016/Help/Files/wwhelp/wwhimpl/js/html/wwhelp.htm#href=02_Interaction.05.086.html#1004370
thanks Cary
2 REPLIES 2
David Maudlin
Cary:
A similar problem was discussed here:
ArchiCad 15 & 16: Cursor Snap Variants
Using the keyboard shortcut still works for me.
David
David Maudlin / Architect
www.davidmaudlin.com
Digital Architecture
AC27 USA • iMac 27" 4.0GHz Quad-core i7 OSX11 | 24 gb ram • MacBook Pro M3 Pro | 36 gb ram OSX14
Q worked. Thanks so much David for the link.
