Showing results forĀ
Search instead forĀ
Did you mean:Ā
Search instead forĀ
Did you mean:Ā
question about truss maker
i would like to create a little more complex 3d structure of a truss. does archicad give me the posibility to use truss maker or, i must use gdl???
10x
1 REPLY 1
David Larrew
If you need more detail than TrussMaker gives you - you will need to make the truss Object manually. You can accomplish this without much GDL - using Slabs, Walls, Columns, etc. to build the truss and then save as a GDL Object.
David Larrew, AIA, GDLA, GSRC
Architectural Technology Specialist
a r c h i S O L U T I O N S
WIN7-10/ OSX 10.15.7
AC 5.1-25 USA
