questions with fills
hi, I have a question about fill tool: how can I adjust the location of the fill lines, make the tiles start from lower-left corner? it is important when we arrange the tiles on floors or walls,
Thank you very much in advance!!
3 REPLIES 3
Srinivas
See Attached.
ArchiCAD Services
ArchiCAD since v9 to latest
iMac, Windows 10
Srinivas
In response to your other post of aligning the fill use the fill handle to rotate the fill pattern, also if you have to align the fill in 3d, please read about aligning 3d textures here.
https://helpcenter.graphisoft.com/guides/archicad-20/archicad-20-reference-guide/configuration/attri...
ArchiCAD Services
iMac, Windows 10
Thank you very much !!
