Geof Gainer
"Close" command gone in AC14
I miss the command-W "Close" in AC14. I used it more than I would have thought. Any move to reinstate it?
AC fan since v 7. Currently on AC 28.1.1 (4100) USA FULL, Apple Silicon,. 2022 Mac Studio, 32G ram. MacOS Sequoia 15.5
7 Replies 7
Just add the shortcut to your Work Environment. (Not really sure why Graphisoft does not treat this as a standard OS X shortcut as other apps do.)
Geof Gainer
Right, but there's no "Close" under the File menu anymore.
Eduardo Rolon
What about Close Project?
It works the same way AFAIK.
Eduardo Rolón AIA NCARB
AC29 US/INT -> AC08
Geof Gainer
It's not on mine -- are you on AC14 US?
Eduardo Rolon
I am using AC14 US.
If you migrated your Work Environment it might be missing the new menu items. See if reseting it brings the item back.
AC29 US/INT -> AC08
Geof Gainer
That's it -- thanks!
Hi Geof,
Been gone all day... The Close command does not have to appear in any menu to assign a shortcut to it. See attached... view all commands by theme or alphabetically to find the one you want to assign a shortcut to, regardless of if it appears in the menus in your work environment.
