"Not enough edges in Generatrix"?
rob2218
what does this mean?
i>u
Edgewater, FL!
SOFTWARE VERSION:
Archicad 22, Archicad 23
Windows7 -OS, MAC Maverick OS
6 REPLIES 6
it means you haven't been reading Asterix!
seriously it usually is an error with the 3d display of an object that has become corrupted.
rob2218
Geeez...more corrupt data?
sheesh...how can I find/fix/corrupt/"destroy" that darn object that causes that error?
what's the process for find the bad culprit?
i>u
Edgewater, FL!
SOFTWARE VERSION:
Binary search: model half of the building, if the error occurs model half of that, otherwise take half of the other. Since you are narrowing down by powers of 2 it zeros in very fast.
rob2218
Oooo...I like that approach Matthew..thanks.
i>u
Edgewater, FL!
SOFTWARE VERSION:
rob2218
....well, I tried the Lohan Method of finding the offending object.
when I model 1/2 the building, the error doesn't show, when I model the other half and "show 3d in selected marquee"..the error does show but....then I model the two halves where the error "SHOULD" occur and the error NOW does not show up anymore??...so I'm perplexed.
i>u
Edgewater, FL!
SOFTWARE VERSION:
You can use the same principle with layers - half on, half off, keep reducing till you find the culprit.
