"Previous" Ghost story setting
I just thought I would point out a nice little new feature in 10 that I just noticed. You can now set the ghost story display to "previous" and is will show the last story you were on as ghosted. Very nice if you are moving between two stories...
13 REPLIES 13
TDabney
Hi Link - thanks for the link (no pun intended (well maybe a little)) to the shortcuts.
Yowza, that's quite a list. I had printed out the shortcuts list from w/in the work environment - show shortcut list in browser - and it's not nearly as complete (the "go to story" dialogue - apple+alt+F2 - is not even on the list!) I'm glad it still exists.
Lars sends his regards.
Thanks,
Tom
TND Architects P.L.L.C.
macOS 12.7
2021 16" MacBook Pro
Apple M1 Max
ArchiCAD 26/27
Link
The show 'Shortcut List in Browser' button only shows commands that have keyboard shortcuts assigned to them, so while it should have listed your 'Go To Story' command, it won't list all commands.
FWIW Graphisoft has been asked many times for such a function!
Link.
aahatimo
Link wrote:
You can find all the new AC10 shortcuts for Mac at:
link,
are there a shortcut differences between the int & us versions? i could not find a us specific list.
thanks,
tim
tim hanagan
aaha! design studio durango, co
27" retina 5k iMac 4ghz i7 os 10.13.6 m395x 4 mb, 32gb ram, 512 gb ssd ac 22 current
15" retina mbp 2.6ghz 1mb 16gb ac 22 current[/size]
Link
AFAIK, no there isn't.
Specialized US Content has been developed and made available here:
http://www.graphisoft.com/support/archicad/downloads/library_updates10/USA.html
Included is an upgrade profile, which I believe does include different shortcuts. I am quite sure the default profile for the US version is the same is the INT version. Someone else may correct me though.
Incidentally, there's a lot more infor on AC10 at the Wiki:
http://www.archicadwiki.com/ArchiCAD_10
Link.
