‎2006-04-06 07:02 PM
‎2006-04-06 10:04 PM
‎2006-04-06 10:34 PM
Mark wrote:Can you post what your figured out? When I have this, it usually means a library has gone bad, and I end up replacing a library with one that still works. Is there a less radical solution?
I figured this out. Thanks anyway
‎2006-04-08 02:13 AM
Mark wrote:This was a bug in a number of the MSA objects ... that was corrected in the DET objects in the SE 9 library.
I set up a new server recently and had to move some files. I opened a file today that I had not worked on in a while. Alot of my MSA objects have a message on them saying "Use Detail Level 1" ...Does any one know why this is happening?
