"Use Detail Level 1"??
I set up a new server recently and had to move some files. I opened a file today that I had not worked on in a while. Alot of my MSA objects have a message on them saying "Use Detail Level 1" and all my pen settings have gone to default!! Does any one know why this is happening?
I figured this out. Thanks anyway
Can you post what your figured out? When I have this, it usually means a library has gone bad, and I end up replacing a library with one that still works. Is there a less radical solution?
Mark wrote:
I set up a new server recently and had to move some files. I opened a file today that I had not worked on in a while. Alot of my MSA objects have a message on them saying "Use Detail Level 1" ...Does any one know why this is happening?
This was a bug in a number of the MSA objects ... that was corrected in the DET objects in the SE 9 library.
AC 29 USA and earlier   ā€¢   hardware key   ā€¢   macOS Taho 26.1 MacBook Pro M2 Max 12CPU/30GPU cores, 32GB
