Starting August 6, 2024, TLS 1.2 will be the minimum required protocol version for Graphisoft products and services that require an online connection. Learn more…
"drag a copy"
I can't find "drag a copy" shortkey and such function in AC8. Previous version have such function. Pls. help.
Go to Options and Work Environment... it is probably turned off in the profile you are using.. OR you could hold Ctrl while dragging and a little "+" will tell you you are drag/copying.. Hold shift also and you can let go of the keys and drag/copy will continue..
“Give a man a fish; you have fed him for today. Teach a man to fish; and you have fed him for a lifetime”—Author unknown
Larry... it's not just you! Many of the posts on ArchiCAD talk can be answered by going to the Help menu in ArchiCAD (Help/ArchiCAD help)
Just click on the "Search" tab; type in "drag a copy"; VOLIA!!!! (see picture attached). No fuss, no muss, no waiting for someone to answer your question on Archicad-Talk. Four mouse clicks, type in three words (as opposed to 19 words in your question (and god knows how many mouse clicks)) and chances were pretty good you would have the answer right away.
And Architalkers... the help menu in ArchiCAD 9 is the best of any version of ArchiCAD ever (I've been using ArchiCAD from version 3.something)
THANKS A LOT!
