radius outside corners
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
ā2004-08-14 06:25 AM
Thanks, Jim
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
ā2004-08-14 04:55 PM
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
ā2004-08-15 05:44 PM
Jim
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
ā2004-08-15 09:19 PM
Thanks, Jim
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
ā2004-08-15 11:15 PM
The attached image shows how it is done, by SEOing the four sides of a slab [matching the window opening size] with a cylinder to make a trimming block.
Saved from the side as an object, this trimming block can be schmoinged into the wall to bullnose the edges of a window opening.
Ba do, ba ding.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
ā2004-08-16 02:06 AM
Jim
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
ā2004-08-16 02:19 AM
OSX 10.15.6 [Catalina] : Archicad 22 : 15" MacBook Pro 2019 [/size]
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
ā2004-08-16 02:37 AM
But you still get credit.
Aussie John's GDL InsertablokĀ® method is limited to solid walls - doesn't work with logs. Not that most of you would care about that - being un-primitive and all.
It would be easy enough to make what I showed in my previous post parametric - then you'd have it all in one object instead of rewriting and debugging several potential window objects....
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
ā2004-08-16 02:50 AM
Im going to patent the insertablock method. Personally i dont care about logwall construction and in any case Im not sure how a successfully log wall has a curved reveal ( but i'm prepared to be enlighted!!)
Also the insetabblock method does work with composite walls but the scripting is tricky.
The reveal detail we are given by graphisoft is rather weak and each individual window shouldnt have to be scripted to turn-in wall leafs /chamfer and curve reveals/ add headers and sills. They should all be part of the window standard features.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
ā2004-08-16 03:04 AM
Of course there is the splayed reveal window opening object that inserts a splayed reveal - worth looking at for scripting hints.
