‎2013-08-20 04:04 PM
‎2013-08-20 09:46 PM
‎2013-08-20 10:28 PM
‎2013-08-20 10:42 PM
Erich wrote:Thanks, i ended up first using a fill or a slab and then applying a zone inside of that with the magic wand. Did a little research and it seems archicad 17 fixed that aspect.
You have it right. Typically you will magic wand the zone into a space. If you need something else, expect multiple clicks (one for each corner)
‎2013-08-20 10:44 PM
Nick wrote:Thanks, i can find the polygon option and use it slabs, fills, roofs or any other element, but when i choose to do zones, that options just isnt there.
You can find the zone polygon options in the info box.
see attached screen shot.
‎2013-08-20 11:55 PM
