I need to make a screened wall... suggestions?
I'm creating a screened in outside deck. But I can't find anywhere to make it. Any help?
6 Replies 6
fuzzytnth3
Make a Complex Profile (the horizontal battens are a simple complex profile in this example)
Or use a library object. The image below is of a simple object made following David Nicholson Cole's GDL Cookbook.
Using AC25 5005 UKI FULL
Thanks for that. But I'm referring to like a bug screen. Very small mesh.
fuzzytnth3
I would do that as a wall and apply a texture that uses an alpha channel to create the holes in 3d and for 2d sections / elevs I would link the surface material to a 2d fill that looks like the mesh you are after
David Maudlin
For this I duplicated the glass material and altered its color and transparency to be similar to a screen material. I wouldn't use an alpha channel texture, the holes are too small. I place simple window openings in a wall, and assign the screen material to the "glass" of the openings to create the screen porch walls. Then as fuzzytnth3 suggests, use a vectorial fill for elevations.
David
David Maudlin / Architect
www.davidmaudlin.com
Digital Architecture
Rick Thompson
Rather than try to describe how I make screen, I'll post screens shots. This is in 17, but 16 etc is similar. I use a dedicated composite. Make sure you have transparency selected in 3D. I place post with a beam at the top, and a rail at the bottom, then run the screen like any other wall.
Rick Thompson
Mac Sonoma AC 26
http://www.thompsonplans.com
Mac M2 studio w/ display
Rick Thompson
Sorry, I should have used the internal engine for the rendering... but you do get a shade difference with OpenGL too.
Rick Thompson
Mac Sonoma AC 26
