rectangular zone?
Hello:
It seems like a simple thing but i just cant find the geometrical rectangular method for making a rectangular zone!.
I just have to use the polygonal option to make manually the 4 sides of the rectangle?, how can i do it?.
5 REPLIES 5
Erich
You have it right. Typically you will magic wand the zone into a space. If you need something else, expect multiple clicks (one for each corner)
Erich
AC 19 6006 & AC 20
Mac OS 10.11.5
15" Retina MacBook Pro 2.6
27" iMac Retina 5K
Nick Schat
You can find the zone polygon options in the info box.
see attached screen shot.
undefined
Nick
ArchiCAD 4.1–22, Mac OS 10.14.x iMac 27" 3,2Ghz Intel-Core i5
Thanks, i ended up first using a fill or a slab and then applying a zone inside of that with the magic wand. Did a little research and it seems archicad 17 fixed that aspect.
Thanks, i can find the polygon option and use it slabs, fills, roofs or any other element, but when i choose to do zones, that options just isnt there.
Seems archicad 16 doesnt have it.
Nick Schat
Apologies, I didn't read your signature, only available since AC17.
Regards
Nick
