replacing current zone stamps with new zone stamp
hi,
we've been working with our project, and chugged away at setting up our zones in all of our rooms. well, now we've finally had a chance to personalize a zone stamp, and i need to update all of our zones/zone catagories to show the new stamp.
when i went to zone catagories and changed the zone stamp to our new one, the already created zones did not adjust.
is there a way to get this to happen with out having to recreate (and renumber, ugh) all of our zones?
the only information we current have in the zones are the names and room numbers. we had modified the zone stamp to show the finish info as we use it, that's our next step...
any suggestions??
we're using AC11, and the file is teamworked.
Something does not work with changed zone stamps. You should somehow be able to get what you want after checking Options>Element Attributes>Zone Categories settings is pointing at the right stamp, and then selecting all zones and checking their settings, perhaps changing their categories back and forth.
But even then nothing is final. I just had to merge the file that had put me through all that into a new file, used attribute manager to transfer zone categories first, and I am finding I will need to redo the back-and-forth reminding operation again.
Check out
http://archicad-talk.graphisoft.com/viewtopic.php?t=18618&highlight=
