reverting custom text dims back to actual dim
overriding the dims has caused a few serious issues.
is there a way to make sure every dim is showing the actual dim and not custom text all at once?
i have tried selecting one of the dim text, clk. dim tool and command A, selecting all dims. then setting all to real dims. -didn't work.
any suggestions would be great. -AC10
Once you have selected all, change all to custom, then back to actual dimension. If the last dimension selected was already showing its actual value you have not actually changed anything.
Stress Co_
An old TIP, but it sometimes helps to avoid confusion.
Marc Corney, Architect
Red Canoe Architecture, P. A.
