reverting to default values
How do you revert objects, walls and curtain walls, etc. back to default settings before you change them?
1 REPLY 1
rocorona
Only Library Elements have true "default settings", the predefined values of the parameters.
For these (Objects, Doors, Windows, Stairs, etc) you can revert to default selecting the element, opening the setting box and clicking on the same element in the left side (Library browser).
For Construction elements, Drawing elements and Annotations there is no simple way, I think, to revert to a "previous" state, if you have performed other operations (so Undo is not an option). Unless the settings were stored as a Favorite.
_________________
--Roberto Corona--
www.archiradar.com
AC18 - ITA full on Win10
_________________
_________________
