Aussie John
ridge accessory?
Does anyone know of a roof accessory that will show a ridge (or flashing)?
Thanks
Cheers John
[/size]
8 Replies 8
LiHigh
The one in Archicad Library is not good enough?
Howard Phua
Win 10, Archicad 19 INT
Aussie John
must of missed that one somehow- will have another look
Cheers John
[/size]
Aussie John
my version of object library 9 only has two roof accessories (roof surfacer and wood ceiling)
Cheers John
[/size]
Gidday Oz
In (my) Object Library 9/ Basic Library/Special Constructions/Accessory Elements there is a Ridge Tile object, which might be what LiHigh is thinking of, but that won't help in the world of corrugated iron down here in the antipodes. Have you tried just using another roof, say 5mm higher than the main roof? Could be a lot of messing around, esp. if you have to alter it later on, but all depends on what effect you are after and the price you are willing to pay to get it.
Cheers
Aussie John
thanks s2art the workaround is quite painful this seems like a perfect use for a roof accessory.
does anyone know how the edges of the roof polygon are defined?
Cheers John
[/size]
Haneef Tayob
Hello
For metal ridge cappings & flashings, I've created a range of library parts (using the slab tool), which I then extrude as I require.
I've had to create different ones for different roof pitches. This works for our office, although with more gdl knowledge, one could create some really parametric ones.
regards
Haneef
Haneef Tayob
Aziz Tayob Architects
AC23 INT rel 3003, OS X 10.14.6 iMac 3.3ghz i5 dual monitor, 24GB RAM
What is it you want to create - a clay tile roof or a sheet steel one?
If it is a tile one I suggest a second roof 4 cm thick and 4cm larger than the first one. And the roof ridge accessoru works very nice with it.
Nuge
you should try the "accessory pack" from Cadimage it will do everything you need and some. i couldn't work without it
http://store.cadimage.co.nz/home.php?page=products&productID=168
AC27 i9 14900KF / 128G ram / GTX 5090 / D5 Render
